RCU Forums - View Single Post - Flycamone ECO and Futaba - PROBLEM SOLVED!
Old 02-21-2010 | 01:58 PM
icepilot's Avatar
icepilot
Default RE: Flycamone ECO and Futaba - PROBLEM SOLVED!
You just connect it to a free channel so you see from the green LED that it has power.
Then you push the small white switch (dot) at the bottom of the print, and it will start
recording, indicated by the LED turning red.
Tor
