RE: Making push rods
Saito 180 uses tubular (hollow) pushrods with hardened tapered or ball ended ends. You could likely remove one end and cut the tube to length and then re assemble the end to the tube. Maybe use permanent Loctite on the reassembled end if it is not a press fit.
