RE: Fox Eagle IV .74
Try running low nitro fuel. It will run just fine on 0% or 5%. Plus you'll get better fuel economy on cheaper fuel.
I usually take 15% for my combat planes and 0% for my Foxes. When I mix them up the .74 becomes very tempermental.
If you have the EZ, air bleed carb, look in this thread, post 545
[link=http://www.rcuniverse.com/forum/m_3354294/anchors_8933919/mpage_22/key_/anchor/tm.htm#8933919]Club Fox Thread[/link]
THis carb modification worked for my 74. The EZ carb tends to lean out in the mid-range then overheat.
The was an informative site that has since gone down called flitelinesolutions.com. I copied some of it to my clubs webpage at [link=http://www.fayettevillercclub.com]www.fayettevillercclub.com[/link]
Navigate to the Fox Engines page and the fix is detailed there. Let us know if it works for you.
