RE: NEW DLE30!
NGK will suggest an .018" gap. .017" saves regapping a lot later. They generally come out of the box at .018" so if there's a visible gap you can jsut about bet it's .018". You can gap wider and let your engine tell you how it's working out. Too much gap makes the engine miss at higher rpm, or simply provide less output.
