RCU Forums - View Single Post - Austars 97" Piper Pawnee
Old 02-21-2010 | 10:58 PM
pc55bomber
Default RE: Austars 97
The cowl is nicely made and has holes that could be used for landing lights if you wanted.
Fitting the cowl was pretty straight forward with not much having to be cutout.
Lining up the cowl screw holes is a pain but all turned out fine.
Just a small a teardrop shaped hole for the plug and 2 small cuts for the pitts muffler.
Used 3mm nylon bolts to secure the cowl as metal ones usually loosen.
Cheers
Paul
ID:	1384398   Click image for larger version
ID:	1384399   Click image for larger version
