RE: Flycamone ECO and Futaba - PROBLEM SOLVED!
Hi Tor,
Yes, you need to get the signal voltage (yellow or orange wire) and the supply (battery) voltage closer together. You can do this by boosting the signal or lowering the supply voltage
As a quick test, have you tried this device with a plain 4 cell NiCad? This will get the supply voltage lower and closer tot he regulated output of the Futaba.
Regards,
