ORIGINAL: dhal22
do i need a pump?
I would say Yes...I saw that fuel nipple on the backplate and assumed it had a pump...The 140 RX is normally a pumped engine but I'm not sure about the EFI version?? I kinda figured it would be pumped too...Hummm
The PD-06 pumps are available for the 140 RX or I suppose you could run a Perry pump if you wanted which would be much cheeper (the one for 2 strokes)...
http://www3.towerhobbies.com/cgi-bin...?&I=LXBZ59&P=7
I remember the ad for that engine when it was listed in the RCU Marketplace and thought the guy said it started out as an EFI engine which was converted to a regular pumped engine...The EFI version was suppose to have that blue head also...
