RE: Twin Engine Install Question
Yes, this was the set-up on my F-14 with Bees. The only problem was an occasional engine not starting (and it would always be the same one). You could definitely tell the one engine that started very "soft", this would be the one that did not get enough propane. The propane has to be consistent, so when the bottle gets low or the temperature is low, you may experience it more often. Powermax would probably be more consistent. Which engines are you using? I have twin Merlins right now and am still getting the propane figured out on them, but they are using single propane source at the moment, but may "T" them when it is all said and done.
