RCU Forums - View Single Post - Nitro Planes Hero 100 Version 2
Old 02-23-2010 | 09:05 AM
Greg Covey's Avatar
Greg Covey
Default Nitro Planes Hero 100 Version 2
The new Version 2 Hero 100 Twin EDF Executive Jet is back in stock at [link=http://www.nitroplanes.com/neheea100fie.html]Nitro Planes[/link]. I'll be doing a full review on this larger 71" span semi-scale research aircraft, posting my build and results here.
This twin-EDF model was designed around dual 101mm fan units and matched D36-2200kv brushless motors. Created for the advanced sport scale pilot, the Hero Eagle 100 ARF is designed for easy assembly and setup using top quality wood construction with a fiberglass fuselage. Just drop in the 101mm fan unit and tighten the screws. The removable front hatch also allows for easy access to the radio equipment and batteries. The entire trim scheme is prepainted, pre-trimmed, and the the wings are covered in quality shrink material. All the decals have already been applied and all hardware and accessories are included.
Specifications:[ul][*] Wing span: 71 in / 1803 mm[*] Wing area: 746 sq in / 48.4 sq dm[*] Flying weight: 14.3lb / 6500g[*] Fuselage length: 71 in / 1803 mm[*] EDF : 101mm / 4.0 in x 2pcs[*] Radio Required: 6channels, 8servos[*] Brushless Motor : D36 x L 50 mm x 2pcs ; 2200 kv[*] Speed Controller : 22.2 v ; 85A[*] Li-poly Battery : 4000mAh ; 25 C
[/ul]
ID:	1385121   Click image for larger version
ID:	1385122   Click image for larger version
ID:	1385123   Click image for larger version
