RCU Forums - View Single Post - Mixed Tamiya Electronics issue... maybe?
Old 02-23-2010 | 09:38 AM
heavyaslead's Avatar
heavyaslead
Default RE: Mixed Tamiya Electronics issue... maybe?
Hello Dave
This sounds like a radio/stick deflection issue more than the Tamiya electronics. I'm musing here but it sounds like the left and right sticking is acting like a trim is not zero'd properly. Maybe a negative shift for extreme deflection?
The fact that you can gently turn from a forward (or reverse position supposedly) may indicate a range near the extreme left or right that reverses the motor direction.
Can this issue be duplicated from a reverse steer direction? Have you tried another radio? Is the crystal socket secure?
Check to see if there is a small range in the extreme left and right that reverses the direction desired.
