RCU Forums - View Single Post - Twin Engine Install Question
Old 02-23-2010 | 09:56 AM
Carsten Groen's Avatar
Carsten Groen
Default RE: Twin Engine Install Question
ORIGINAL: YellowAircraft
Hey,
Any of you guys ever had your two engines sharing a common propane tank teed off to the respective solenoids? Any problems?
Shaun,
if they are JetCat's, there is a setting in the ECU that enables you to start one engine after the other, the sequence is a combination of the throttle stick and the AUX channel, looks easy enough to do
