RCU Forums - View Single Post - Valiant By Bryan Hebert (First Flight)
Old 02-23-2010 | 10:51 AM
  #49
flyncajun
Default RE: Valiant By Bryan Hebert (First Flight)
Thanks Volkert
Dick, Yes the 822 header is the one you need, use the 37mm pipe standoff.
I use the 18oz Tetra crank tank ,,dont use the 17oz it`s not the right shape for the tank mounts
cut/sand the tank mounts so you can add split fuel tubing to help with wear on the plastic ,,,see link below how I do it.
on the carbon rod /titanium ends the short one are all you need. you want the 2.5mm rod ends
use 2.5mm MK bb linkage/ 6 adjustable rod ends and 4 bb clevis ends,,if you use two on the rudder pp. you only need two for ailerons otherwise (caution some may be drilled oversize make sure you test fit and use blue locktite on the bb clevises)
The chs Variable angle clevises are fine But be carefull sometimes the factory does not put the wood blocks in the wings in the same place (where you need to put the horn) So I just glue a 3/8 dowel in the ailerons and drill that, it`s much better in the long run.
On the elevator halves I use the supplied horns in the kit
Tetra PP is fine.
use a central Hobbies nose ring,
I have included a link so you can see how I set the proto up ,,a lot of good picks to look at
It will help you with the building if the instructions are not up in a week or so.
Put the CG on the middle of the tube / that means the battery will have to be close to the front,even with the CDI unit.
On the fuel I can Call Cool Power if you need, to know who the distributor is there ,But,
you can use regular Heli fuel just a little more smoke anyway.
Bryan
