RCU Forums - View Single Post - Engine right thrust or rudder slaved to throttle?
Old 02-24-2010 | 06:37 AM
Tony Hallo
Default RE: Engine right thrust or rudder slaved to throttle?
When you mix rudder to throttle you have the ability to turn off the mix when not wanted, when the right thrust is built in, it there to stay. The trimming for right thrust is long verticial up lines, the pilot is expected to use rudder during takeoff. My planes have 2 to 3 degrees of right thrust and require the use of the rudder during takeoff.
