RE: YS-170CDI Flight Report
Colin,
I'm using the YS super Mount, the vibration on the airframe is really low compared to the 170 with no CDI, and I'm getting 137mAh per flights as I mentioned, actually it's about 10mAh more or less depending on the wind but the average is 137mAh.
If you can use two batteries I recommend you to do it, just the peace of mind worth it, and you will be able to get those 5 flights, really, if I do it you can too.
Regards
