ORIGINAL: noahb
its when the wing and aileron or other control surfaces use the skin of the wing as the hinge. As in composite airplanes like the comp arf flash. When you look at it, all you see is a crease where the hinge line is. Like folding a paper airplane and then bending an aileron on it or to that effect.
O.K. ... Got it !!! I built a couple of Eurosport's that use that... Just threw me cause I've never heard it called that before !!! Oh well, learn something new everyday !!!!... Thanks for the answer !!!
Danno
