RCU Forums - View Single Post - ENGINE DOWN AND RIGHT THRUST
Old 02-24-2010 | 11:46 PM
nitro wing
Default RE: ENGINE DOWN AND RIGHT THRUST
Check up/downthrust in a level/trimmed powered flyby. Cut throttle. Obeserve up or down pitch. Ideally it should continue level for a ways.
Back to full power. It should not pitch up or down, but continue a level flightpath. Adjust engine thrust to achieve a neutral behaviour.
Side thrust is checked with a level powered flyby, then smoothly pull into a vertical. If you need execessive rudder to draw a vertical line, adjust thrust line L or R
Your flying surfaces must meet required incidences per manual before the above is tested with success.
