hello:
I think that you can repair if use the same hinge nylon and cover it with fiber glass (for the botton side, not over the paint.
For you are sure that the hinge run perfect you paint the center of the nylon with wax paint for childrens, do you know ? this way the epoxi not glue in the center and the hinge will work perfect.
you an see it here:
http://picasaweb.google.com/cmjets20...40381312378482
Try it. I hope work fine.
Regards from Spain
Carlos.
______________________________
http://cmjets.blogspot.com/
