RE: What The...? Wheels steer to the right after gyro initialized
Well, Yes and no. I tried to get rid of the creep. but if I let it center itself, and set the horn to 90, I run out of right turn on my steering servo, so I just trimed it out on the transmitter. It's only about 4 or 5 clicks. I was mainly worried it would pull to the right all the time. Heli expert at LHS said not to worry about it, when the cars running it will take care of it's self. Alot of guys on the forums are not real fond of gyros in drift cars, I only have about $20 into the gyro.. guess I won't be out a lot if I crash and burn.
I put on a set of buggy front spring all around, blacks(front) and greens(rear) took off silver and gold TC3 springs, really soft now, 3.5lb front, 3.8lb rear, with 3mm ride height clips at each corner, 11mm chassis ride height... No clue what I'm doing so.. I'm kinda winging it now. Drift class is pretty new at our track.. Carpet Oval.. Saturday will tell all!
