RCU Forums - View Single Post - dp ultimate w/os 1.60 problems
Old 07-13-2003 | 08:41 PM
MarkNovack's Avatar
MarkNovack
Default Where is the regulator mounted?
If your regulator is mounted directly behind the carb, the motor will be difficult to tune. On the OS160FX, the regulator should be mounted just before the needle valve fuel entry. Use no more than 1" of fuel line between the two. It can just hang there or you can mount it against something if it is convenient.
That is all I can add.
Mark
