I uploaded a video of the info display on youtube, it was dark,so the quality of the video stinks
Anyway, it gives you a feeling about the display. The "max pump" voltage screen that shows the "max pump voltage" of the last run and the one before and lowest battery voltage detected, is not implemented yet.
There is a funny "feature" of the ECU, whenever it is in "PreHeat1", it won't communicate for a couple of 100ths of a second, so you see a error message between PreHeat1 and PreHeat2 (will be fixed tomorrow), and there is a cosmetic error on the "fuel/minute", it has the decimal part with also, that has since been removed. ANother thing missing is the ounce conversion, right now it is only in milliliters, will also be selectable
Hopefully Sandor (Digitech) will get one of the prototypes from me in time, so he can bring it to Florida Jets
Again, sorry for the very low quality video, I will shoot another one tomorrow in daylight, but until them
One small note, the reason for it stays so long in "LearnLo" state is that I forgot to put the throttle stick down to idle again after the starting sequence was initiated
Engine is a P160SX
[youtube]http://www.youtube.com/watch?v=8D9-ARtMfEk[/youtube]
