RCU Forums - View Single Post - control rod sodering
Old 07-13-2003 | 08:31 PM
JohnBuckner's Avatar
JohnBuckner
Default control rod sodering
Yes silver solder is good but if you don,t want the expense then use acid core and wire brush after cooling and wash in soap and water will result in no more rust than the base material. Frequently use it on up to three sixteenths music wire for float struts a very rust pron environment, no problems.
John
