it took me 3 models to get to the point where i can cover and make it look good where i get comments on how it looks (as long as i hide certain parts
the first one was horrible but it was so simple that i didnt really care, the second was better but far from good, the mojo, my third looks good for the most part but there are parts where you can tell i was having a bad time.
the ultra sport im building is so much better than the rest their are no big screwups just little things which i will get better with time, the curves actually curve, instead of having like 10 patches cause i burned a hole in the monokote.
my point is dont get pissed at the covering, at least you can say you built the plane, if an arf guy laughs at you. a kit builder will understand.
get a heatgun and a covering iron. the heatgun is where its at, once you master the heatgun then your a good. the key with the iron is to not iron folds in the covering which cant be takes out by the heat gun. if the covering is just wavy the heatgun will take care of it but once covering folds over and irons to covering your screwed.
some say you dont need a heatgun, well their wrong
, idk how they would do it but i use my heatgun as much if not more than my iron
the mojo isnt that hard to cover, just cover the fuse before you put it on the wing, then cover the wing.
also stick to simple schemes until you get the hang of it, it makes it so much easier and you will get in the air faster
sorry for the rant
