RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 02-26-2010 | 11:32 AM
  #577
MTK
Default RE: SAP 180 (Syssa Performance)
ORIGINAL: cmoulder
Matt, a lot of guys will be happy in the spring for the accurate tuning info and tweaking you're doing now!
Stretched the pipe by 3/8'' and that, combined with leaner low end, eliminated the jumpiness at 1/3 throttle.
This is a big development. I was kinda worried about that because mine jumped pretty big thereabouts.
the distance from the plug CL to the end of the pipe (not including the stinger) is 33 1/2'' straight line. That's approximately 27 1/2'' plug to baffle.
Very handy number, so we don't have to stick something down the pipe to figure out where the baffle is.
Top end rpm is higher than my ear perceived originally...I tached it at 8200 after the changes. Pretty terrific!! Throttle response is now about as linear as anything I've played with before and with the amoun
The thorobred can be tamed. Excellent developments.
Bob, thanks,
I want to make sure that folks get the fact that these numbers are true only for the ES 30G pipe. If someone has the ES 40G or the smaller 26G, the numbers would be different to the end of the pipe. BUT the numbers to the baffle should be very close to what I've determined so far on the 30G.
The Mintor aluminum pipe for the 37 cc engine has the baffle at very similar location to the ES30G. I wish I would have held on to that pipe. It would have made for good comparisons.
Matt
