RCU Forums - View Single Post - Help with large scale setup.
Old 02-26-2010 | 02:22 PM
Bill Martins's Avatar
Bill Martins
Default RE: Help with large scale setup.
ORIGINAL: BHunn3
I’m in the process of expanding my knowledge into setups for larger scale aircraft I have a scenario I’d like you to consider, get recommended setup, and answer a few questions maybe.
What would I need to setup a redundant system for a plane with the following requirements; and can your setup run off a nine channel radio(2.4Ghz) 11 digital servos (2 on each half aileron and elevator, and 2 on rudder, plus a throttle servo and a payload drop servo. So what would your initial recommendations be so I can ask more questions. Thanks.
B,
You might contact R Richey at smartfly rc. He should be able to answer your question, or at least give some help.
http://www.smart-fly.com/Contact/contact.htm
Hope this helps.
Bill
