RE: Wire Size/Type from ESC to Batteries
dave,
maybe with mine it might be because im not running a real high voltage set up, i have a hangar 9 B-25 with 2 monster power .46 motors running 60 amp volcano esc's on 4s 5000 mah packs ? the wires run about 20 inches to each esc from the battery packs.
BTW im using 12 gauge high temp noodle wire from deans.
so could it be the higher voltage set-ups that are at risk ? ie 5s and up ? any info on this is greatly appreciated.
bass
