RE: Another new boat LOL!!!
Took the boat out today for its first run since i got it. The boat ran ok needs a little tunning but is already way faster than my gator lol. I need to set the trim tabs cause at full the throttle the boat was lifting up all the over the place. Also there was a little water in the hull and i dont know if came from turining so hard and water splashing over the bow? It maybe from not having a enough grease on the flex cable could that be? I pulled it out to inspect it and there was a little water on it so I cleaned it up and put a thick layer of grease on it for tomorrow. Im gunna try and tune it a little bit more tomorrow seems to be bogging down at the low end? So will see tomorrow.
