RE: Correct Alignment
first question when you say the motor is angled to the left are you talking about looking at it from the front or from the back. all the people here know to use sitting in the pilot seat as there reference ofr left and right and most plane are built to have an automatic right thrust. so is your thrust really left or is it right. Left thrust on a trainer will make it fly a lot more funkyier then you would expect. otherwise all the other alignment settings on a trainer are fairly forgiving if they are relatively close
