1/3 Stearman questions
Hello Everyone
Hope no one minds me posting here this is not an aerobatic aircraft as such
but I tried posting in the scale forum with no response.
I have a 1/3 scale Stearman 116" ws. built off Balsa USA plans.
I have the wings, fusalage and empennage ( tail sections ) all built
and I'm about to make the final mount on the wings and flying wires.
I have other bipe's but none this large and hope some who have this or
other large biplanes could share some information.
The plans call for du-bro 1/4 scale forks on the ends of solid
music wire for the flying wires. These have a bolt that slips through
one side and the wire bracket and thread into the other side, to trust
this setup I would extend the bolt and add a ny-lock nut, to much tedious
set up and take down at the field. I've searched but have not found
much for a substitute.
I sure would appreciate any information from those that have built
this aircraft or other large bipe's on how you did your wires and
I have built spring loaded functional landing gear that I can adjust
the initial load on the springs. The plane will come in 45-50 pounds
and I was thinking of setting them around 30 pounds on each side good
or bad?
Last question. In my searching I found many had a 150cc for power and
I have a 3w150. I also have a 3w106 but wish I had a 120cc
I found most had to add 4 to 8 pounds to the nose to balance soooo...
of the the 150 and 106 what would be the choice?
I'm not trying to have a 3D aircraft (of course it's not) but don't want to be under powered
either. The 150 is 2 pounds heavier(help on nose weight) but a little marginal on
prop clearence, will the 106 have a little power to spare?
Thanks ahead of time for any help. Hope I post this right I don't post very
often.
Best Ron
