I recently purchased this plane:
http://hobbyking.com/hobbyking/store...m_EPS_Foam_kit
I installed the following Motor and ESC for it:
http://hobbyking.com/hobbyking/store...idProduct=6678 (the XL motor I used for this plane)
http://hobbyking.com/hobbyking/store...idProduct=3727
As I fly it, no more than couple minutes the plane started to lose power. I look at the motor, ESC, and 6S 4000 mAH Lipo that I used was hot. What happened? If these aren't really the right motor/ESC combo for it, then what motor and ESC is perfect or should I use for it?
