RCU Forums - View Single Post - another os120fs surpass problem
Old 03-01-2010 | 12:04 PM
combatpigg's Avatar
combatpigg
Default RE: another os120fs surpass problem
It's hard to tell from the photo, but the pile of rubber next to the rod could be what's left of the bearing retainer / shield?. Once you get it cleaned up, it will be obvious. There are several good tutorials about replacing bearings if it comes to that. You want to look at the piston / liner under magnification to see if the engine is worth messing with. The cost of these parts can make doing a rebuild not practical.
