RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 03-01-2010 | 01:57 PM
  #1021
Rallyfinnen
Default RE: New CDI - opensource project JMJ and Bigboat
The idea is that you measure and filter the interval between the pulses, and constantly estimate the rotor position, based on this interval measurement. Every time a pulse is received, you calculate the difference between the estimated and measured position of the crankshaft, and adjust the estimated position by a fraction of the difference. That way, you always have a fairly high-resolution live estimation of the crankshaft position, which is constantly adjusted but small amounts, and keeps tracking the actual position.
This way, it doesn't matter exactly where the sensor is, because the switching events are related to the estimated crankshaft position, and not directly to the sensor input.
I'm having some thoghts about this, would this mean you have to use an old rpm value to base your delay on (two revs back in time?) I know this can cause problems in engines with quick throttle response, that the ignition is 'lagging' when the rpm rises quickly. Not sure it's an issue though, just a thought.
I guess the optimum would be to use a multitooth trigger wheel, but it's not really an option here
