RE: FLy Eagle Jet Models
quick update,
i tried to maiden this weekend but i got problems with my fuel system so i aborted. i got too many air bubbles in the fuel line to the turbine to the point that the UAT was 90% air!! i took it back and disassembled the tanks and found that the centre fuel tank nipple fitting was leaking (which was BVM btw!!!!!!). i put thread lock and solved the issue. secondly, i found the seams on the tanks was leaking too. so i added thin CA on it and left it to get in the seams. i tested the tanks filled them back and forth several times and all seams ok. am not sure of my tank seam correction method?? did u guys face such problem before?
KAON
