RCU Forums - View Single Post - Extreme 330 control throws
Old 07-14-2003 | 02:05 AM
bentgear
Default Extreme 330 control throws
There are some good threads started on this plane, you might want to do a search.
3/8" is not enuff to do anything with, but it keeps you out of trouble on the first flight. My sugggestion would be go with 1/2" on low rates and go double that on high. My low rates are about 3/4" + and highest rates are 45 degrees + on elevator and aileron and all the rudder can do.
Fly it and adjust to your needs. My high rates can be a hand full on aileron and elevator if you are not expecting it. I do most of my flying on mid rates that are the rudder maxed out and the elevator and aileron at about 30 degrees.
Ed M.
