RCU Forums - View Single Post - Do you measure static thrust of your engines?
Old 03-02-2010 | 08:21 AM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Do you measure static thrust of your engines?
I've built a lot of scratch scale aircraft and I always look at the static thrust of engines to see how well the plane will get pulled down the runway.
You can get good static thrust with most engines, it just depends which prop you use, it is almost useless to know what it is.
