RE: E flight trimming question, motor thrust
Two things to consider on your stall question. Is there any wind? This should only affect one direction though, and also, are you 100% sure you are totally vertical? Most people tend to lean one way or the other and this would impact that. A quick test is to pull vertical and just touch some left rudder to where it is slightly leaning to the left and see what it does.
Arch
