RCU Forums - View Single Post - Pipe Installation Question
Old 03-02-2010 | 04:19 PM
Shaun Evans's Avatar
Shaun Evans
Default Pipe Installation Question
Hi,
I know the ideal case is that your engine/bypass is perfectly centered up with your pipe, and that if you ran a laser through it, the engine's shaft would be perfectly lined up with the center and longitudenal (sp?) axis of the pipe. My question is, how "off" is too off? If, for reasons I care not explain, the installation is off-center a tad, how much effect have you guys seen? TIA
