RCU Forums - View Single Post - JR 9711 Elevator servos twich big time??
Old 03-02-2010 | 09:52 PM
Mavrik!
Default RE: JR 9711 Elevator servos twich big time??
ORIGINAL: tp777fo
Had the ''bumps'' with a JR9303 with the TX the menu mode for an extended period of time as I was making adjustments.
Not in menu mode when it happens either as happens in flight and on the ground.
I do note it happens when the turbine is running which happened on a ground run 2 days ago. Huge elevator deflection. Does not happen to any other model I have with this TX (11 models) so it can only be the JR 9711 servos??
Will ferrite rings in the leads fix the problem? Or should I just swap them out and give up on them????
Mav
