RE: 808 keychain cam, how do u use this thing
The Key Chain cam needs a micro SD card to function or it will shut off. The one I have is so simple to use once you understand it that it is almost self running. First insert a micro SD card then you hold down on the button for a second then when the light flashes it is ready. press once and it takes a still photo, press and hold till the lights blink then you are in the video mode. The minuscule print in the manual is somewhat fair chinglish and if needed email the seller for a pdf of the manual that will help a lot. just keep messing with it and after a few tries it should be working how you want it too. Also the softwae needs a lot of attention if you want to have the date stamp correct!
Larry.
