RCU Forums - View Single Post - Super Tigre 3000 engines-need info
Old 03-03-2010 | 04:43 AM
Gabrielsande
Default RE: Super Tigre 3000 engines-need info
Hi yes it will be nice to leave the original mount, but the, prop hub sticks about 60 mm further out of the cowllinethan with the crrc pro 26i, and the crrc pro is against the firewal, I can move the cowl 20mm foward, but will need to drill more suporting holes and still 40mm to go!, so I have to work out how to move the firewall back the tank is nearly over the wings so there is nothing on the box, but is one of those light frames, and I have to be careful not to add too much weight to it it flyes very well with the crrc pro, Imswappingit just to have a tad more of power and I know the saito it will sound better and last longer. I will post more pictures once I have the engine to compare against the crrc pro26i thankss
I bought this plane from china, www.cyclonetoy.com ,sold in uk also from www.globalrc.com.uk, and if you want to see nice pictures and videos of this plane flying go to www.axarmodel.com
ID:	1390270   Click image for larger version
ID:	1390271   Click image for larger version
