RE: Hangar 9 extra 260 27% what engine
<div style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: rgb(255, 255, 255); font-family: Arial; font-size: 12px; background-position: initial initial; background-repeat: initial initial; ">question for you guys. I'm thinking of mounting a Evolution 45 GX2 to mine. The only problem i have never mounted a gasoline powered engine. So how is it done. I'm guessing you find the thrust lines on the engine and then line it up with the thrust lines on the firewall so that i lines up with the cowl also???<div></div><div>ALso, if this is the way it is done, where can i find the thrust lines on any Gas engine. I also have a funtana 125 that i hope to put a DLE 30 on.</div><div></div><div>By any chance, would the thrust line be indicated by the little lugs that stick out on the crankshaft?</div><div>
I know for a fact though that the DA engine don't have those, but the 3W do. So for those that don't how do i proceed?
3DKunald
</div></div>
