RCU Forums - View Single Post - FS One by Hangar 9
Old 03-04-2010 | 09:01 AM
  #1962
da Rock
Default RE: FS One by Hangar 9
ORIGINAL: CloudSkipper
ORIGINAL: sctholson
Check here for additional info about wind conditions:
********** edit by moderator
********** Scott, your direct link into RCGroups brings up something altogether different now ***********
********** it gives a list of 4 possible threads (looks like the response to a SEARCH), none of which are FSOne wind threads **********
********** you may wish to sum up in your own words what it is you wish to share with us ******************
daRock: edited inappropriate link out and replaced with suggestion
I provided the updated link. I was not a ''temporary result from a search''. It was a static direct link to a post:
http://www.rcgroups.com/forums/showt...6#post14345426
daRock, you probably encountered a db error or something when you clicked it.
The link you provide actually takes me directly to a window that has at least 4 threads/posts in a list. None of them have a subject that suggests anything about FSOne. I just now went again and got exactly that same list. It is titled: "Similar Threads", and the similar threads are dated Sep 2009, Apr 2005, Oct 2003, Apr 2002 and none has a subject that seems to have anything to do with FSOne going out of production, which seems to be the "similar threads" found by a search.
HOWEVER, when I selected the list in order to copy/paste it here, the action seemed to trigger movement from the list to a thread that did in fact contain the information you probably wished to share here.
It may or may not be a "static direct link" to a post but it doesn't seem to go directly to a post at all. It's within the RCUniverse rules to provide a link to a competing website/forum and your link would be within those rules most certainly as it provides information pertinent to the topic of this thread, but the link certainly is a pita to use. I can only guess that everyone who hasn't been down that path would see what I saw, which is why I edited your previous link.
Thanks for providing a link to more information. Let's hope it works better for everyone else who clicks it.
