Q1054
Wow! Looks like we forgot to remove those 'works in progress' wind files! Who knows what other files were left in the attic ...
The Q1054 TurbBL wind file mentioned above is here:
http://www.inertiasoft.com/fsonefaq/...urbBL-Wind.zip
This wind setup includes a 10-mph wind component + turbulence + ground boundary layer. It has "all" the elements that are encountered in a real wind scenario (especially landing). Use the 'w' key to see the wind speed and direction.
We did not include turbulence with a ground boundary layer along with the original FS One HH install. Running an atmospheric boundary layer together with turbulence requires ~twice the computation on the wind side of things. It will not be so great on slow computers, but who still has slow computers these days?!
If you try it out, you'll notice that as you get closer to the ground, the wind speed will decrease and in a crosswind landing this will require less correction. The turbulence adds in the random element.
- ooo -
To install, unzip the file, look at the readme file, and move the contents to your FS One HH "Wind" folder. Then edit the wind list here:
C\:Program Files\FS One\Wind\Lists.cfg
and add this line to the list and end the file with a blank line, e.g.:
Name217 = turbulentwind-10mph-000deg-GroundBL1....or whatever number increments the last, e.g. Name220 if following the prior post.
