RE: Proctor Mini Anti-Bipe (with mods) Build Thread
Steve, I finished covering my fuselage and today shot a coat of clear poly from a spray can onto the bottom of the lower wings. Looks good so far, sure a lot easier than getting out the spray rig, etc. I'll need the fuel proofing so that's why I'm using clear poly. By the way, I've forgotten, are you using pull-pull cables for the rudder and elevator as I showed in my earlier photos? If so, before you cover (am I too late?), take some measurements of where the cables exit the fuselage so you can poke holes in the covering in the right place after you cover. Probably preaching to the choir here, but if I don't say something when I think of it, it's gone [&o]. Tough to get old. Lee
