RCU Forums - View Single Post - Proctor Mini Anti-Bipe (with mods) Build Thread
Old 03-05-2010 | 08:52 AM
  #106
insalacosm's Avatar
insalacosm
Default RE: Proctor Mini Anti-Bipe (with mods) Build Thread
Hey Lee - Glad your making some progress and thanks for the tip. I was planning on using some construction paper to mark the exit holes. Yeah, I'm running pull pull rudder and elevators just like you did. Still trying to figure out how to secure the elevator bellcrank inside the fuse. The problem is that it's pretty tight in there and I need to be able to access it to attach the clevises.
I have one wing rigged up and it was actually pretty straight forward. I still, however, need to finalize my wing attachment mechanish for the wings. I'm probably just going to use brass tabs that I can screw into a hard mount in each wing panel, similar to how you did it. I notice that you only have one fastening point per wing panel, do you think this is adequate?
I'm now also leaning towards putting servos in the bottom wing and using a stiff pushrod to connect the upper aileron. I think this will just make setup/break down easier and will give me a better setup.
Steve
