ORIGINAL: Velco
ORIGINAL: hezik
Another nice option would be the AXI 5325.. available in 8s and 10s version.
580 grams.
According to flight reports the 5325 is a viable option for a 2m F3A bird (both the 8s and 10s version), so it should reak havoc on a WindS 110.
Can a motor with 63mm diameter (like 5325) be installed on the Wind 110? It would be great news if that is the case, together with 19x12 if there is no clearance issue.
Anything over 53mm you have to start cutting the motor support. 63mm will risk the motor can rubbing the bottom of the plane or 'floor'.
