RE: wood prop vs E-Prop
If it is a wood prop designed for glo then it will be thicker and not as effecient as an E prop. The APC are good E prop's The Xoar's are lighter and pull less AMPS for the same size. In some sizes they may be more effecient.
Do not waste your power with an electric motor useing a glo prop, wood or plastic.
I know this is late but
Dennis
