ORIGINAL: gaRCfield
ORIGINAL: gaRCfield
ORIGINAL: ODD
I ordered a Wind 110. Can someone please let me know the size of the aileron servo wells to help me decide what servos to put in.
I am planning to buy for the Wind the T-Canalizer and wing fins that comes with the 3D Stabs. If any one is interested in the 3D stabs, please let me know.
I am not home to measure, but I used the Airtronics 94772 in the ailerons with zero modification or sanding. They are a pretty nice servo, very fast with excellent centering.
13/16 x 1 5/8'' opening for servo body, not including mounting surface.
Thanks Joe for measuring the size of the servo well.
I plan to use the Futaba S9551 for the ailerons, which are 41mm x 20mm, so sound like they will fit.
Hezik,
You mentioned you have unlimited verticle with your setup. By that do you mean that the Wind accelerates while traveling up perfectly verticle? Have you made RPM measurements with the various prop and battery combinations (e.g. 18x10 w/8S, etc.)? What is the final weight of your Wind?
