RE: Welcome to Club SAITO !
Started my Saito 91 with an electric starter. had a higley heavy hub on it, but no lock nut. The hub and prop came off in flight. Now I cannot get the engine started. I re-set the valve spacing to .002, but have been told the timing could have jumped from the engine over revving. Could this be true? Should I check the timing? The engine seemed to run fine before this.
