RCU Forums - View Single Post - THROTTLE POSITION
Old 03-06-2010 | 04:26 PM
stevenmax50
Default THROTTLE POSITION
Here are some pics of the throttle on my Magnum 91. I have looked at this thing from as many angles as I can see. The bottom line is that the throttle arm protrudes from the cowling. I am having a problem attaching the contro rod. I have the engine out as far as it will go on the mount and of course, the mount is centered on the firewall. I have looked at removing the throttle and reinstalling it with the arm reversed. It doesnt look like that can be done. And the problem is that there is not enough room between the throttle arm and the firewall to make a bend in the control rod. I am using a standard clevis. Is there something else I should be using to give me more room?
ID:	1392212   Click image for larger version
ID:	1392213   Click image for larger version
ID:	1392214   Click image for larger version
