RE: Coverite fabric problem
Are you referring to the unpainted Coverite? If so, try a higher heat on your iron. I recently heated an area that was giving me problems with the iron on full hot (325 degrees). It pulled tight but did not melt. Try a test piece first, but I don't think you can melt it with a hobby iron.
Paul
